Easiest way to scale x-axis values in MTF plots?
  • December 30, 2021
  • 314 views
Donna.Waters
What I’m really trying to do is show the MTF in object space (what I would get if I reversed the lens and plotted MTF).  I believe all I need to do is scale the cycles/mm axis by the magnification.  Not sure how to do that without exporting the data to some other application.  Can it be done in ZPL alone?
Best answer by Jeff.Wilde
I don’t know of any way to simply replace the x-axis data in a standard analysis plot window.  However, you could try the following.  Use a pair of paraxial lenses following your image plane to implement a magnification change (via the ratio of the lens focal lengths).
Then the MTF frequencies scale accordingly.  Here’s an example with a 2X magnification adjustment:
In the first graph the surface is chosen as the original image surface, while the second graph uses the new (magnified) image plane.  It’s very simple and doesn’t require any programming.
  • 518 replies
  • December 30, 2021
Yes, I think writing a ZPL script to do this should be relatively straightforward.  You can loop through a range of image-space frequencies, using GETMTF inside the loop to find the sagittal and tangential response values for the field(s) of interest.  Then the system magnification can be extracted using GETSYSTEMDATA.  Lastly, a new plot using the scaled frequencies can be generated using the PLOT keyword.
Donna.Waters
  • 30 replies
  • December 30, 2021
Thanks Jeff!  Do you think there’s any way to directly replace the axis values of the default MTF plots, rather than create new plots?
  • 518 replies
  • December 30, 2021
