Scatter dll not visible in Zemax OpticStudio Premium
  • May 26, 2020
  • 136 views
I have a Global Academic Program License for OpticStudio, and from my License Manager I see this license is of type 'Premium' which should give me the possibility to use dll scattering model. I have downloaded one of Luminit's scattering dll and placed it in the correct folder, but nevertheless the model does not appear in the user defined scatter model list!
Is this a limitation of the academic license?
Chiara
Andrew.Dennington
I had the same problem with a different DLL and the problem was due to the way Zemax installs with duplicate folders.  I've folders C:\ProgramData\Zemax\DLL, C:\Program Files\Zemax OpticStudio\DLL and C:\Users\Andrew\Documents\Zemax\DLL.  The correct folder turned out to be the C:|Users one. To check that you are looking at the correct folder just delete one of the DLL files.  If the DLL does not disappear from the drop down list you are looking at the wrong folder.
If anyone from Zemax reads this please can you stop this idiotic duplication!
Andrew
  • May 26, 2020
Hello Andrew and Chiara,
I would recommend looking in the 'Folders' tab of the 'Project Preferences' to see the correct place to store files.
As for the the different places to store files, after version 17 came out, all the DLLs and other files were moved to users\documents\Zemax from the program files location. I imagine the newer version were downloaded over the old version and that is why it looks like there are duplicates of all the files. This knowledge base article discusses the file location in the {DATA} folder: https://my.zemax.com/en-US/Knowledge-Base/kb-article/?ka=KA-01532#addendum
-Kaleb
  • May 27, 2020
Dear Andrew and Kaleb,
Thank you for your answers, I figured out which was the correct folder and I managed to load the dll.
Chiara
