Increasing max diffraction order beyond 10 for RCWA analysis dll
  • Aug 2, 2023 9:24 PM UTC
  • 216 views
Malkiel
 According to Zemax’s online help https://support.zemax.com/hc/en-us/articles/1500005578722-Simulating-diffraction-efficiency-of-surface-relief-grating-using-the-RCWA-method, for the particular diffraction grating that we are trying to model,  we need to increase the Max Order parameter.
In the help on “simulating diffraction efficiency  of a surface relief grating using the RCWA method” authored by Michael Cheng and updated on April 28, 2023 under the subsection Max Order it is stated
“This is currently limited to 10 (totally 21 harmonics). When the number is larger than 10, it’s modified to 10 in the DLL. Contact support team to increase the limitation.”
What is the procedure to increase the limitation?
Best answer by Allie
Hi @Malkiel - great question! I chatted with Michael Cheng about this. He told me that users can submit their requests to our team via a case created on the zemax.com portal, or directly to Michael on the forum post below:
We received your request and Michael will be updating the DLL. We expect it to be updated in the next release: 2023 R2.02. I’ll reach out individually to you to see about getting you a beta test of the new functionality.
Allie
  • Aug 4, 2023 10:27 PM UTC
Malkiel
  • Aug 4, 2023 10:46 PM UTC
That would be much appreciated.  Thank you for your help!
Malkiel
  • Aug 21, 2023 11:01 PM UTC
This helped.  Thank you very much.
