GRIN Media Definition of Dimensions
  • Mar 12, 2021 10:03 AM UTC
  • 167 views
for example for the GRIN3 Media definition what are the units for the refractive index in z-direction if you set a value in the object properties? In case of Zmax standard units is mm, is Nz1 from 0.001 defined as (0.001 n/mm)*(z [mm])?
Thank you very much and kind regards
Julian
Best answer by Mark.Nicholson
Yep. It has to resolve to a dimensionless number so if something goes as alpha*Z^n then alpha must have units of Z^-n
