ZPL Macro: Sequential Manually add step wise compensation to MC files
  • Jul 23, 2021 12:08 AM UTC
  • 388 views
Allie
This macro applies incremental changes to a compensator in Monte Carlo files, then reports the updated criterion. It will cycle through Monte Carlo files and apply a discretely-valued compensator to a particular surface. Then, the criterion will be analyzed and reported. (Note, the report could use some formatting updates). This code may be used to represent step-wise compensation tools. For example, a mirror's tilt may be applied as a compensator to a change in the system. However, it may be the case that the mirror's housing makes it so that the mirror is only allowed to tilt in increments of 2 degrees. This macro will cycle through the MC files, apply the incremented compensation up to a particular boundary, and will report the result. The changes to each file are NOT saved.
Language: ZPL
Click here to download
2020/02/07 1.0 20.1 Creation
