STAR: Load FEA data with your command line
  • Nov 15, 2022 8:34 AM UTC
  • 201 views
Allen.Cheng
I put all the scripts and detailed documents in the zip file, “star_load_fea_cli.zip”. The script “main_cli.py” is a command line tool that I use to import the FEA data to the system via the STAR module. The feature is almost the same as the “Load FEA Data” tool in the STAR module. The difference is that this tool cannot help you check whether the FEA data is in the right place. However, it might be able to help you finish some routine work. If the script is not convenient enough to let you finish your work easier and you want to build your own tool, I think you can reference the functions “load_fea_deformation_with_transform” and “load_fea_temperature_with_transform”. I believe that they will give you some help.
