Obtaining a tight focus of laser beam after a multimode fiber
  • October 30, 2024
  • 388 views
cmanoopckr
Hello guys,
I have a multimode fiber of 1mm core (1000 um) of 0.22 NA. I will be using this fiber to deliver my laser beam of wavelength either 450 nm or 530 nm. The beam after the fiber will be collimated and then will be refocused. The final goal to have a spot size of 50 - 60 um at the focus. I am beginer in zemax and any help would be appreciated. If any of you had done similar project in the past it would be helpful if you could share the file and i could use it as starting point.
Thanks a lot.
  • November 7, 2024
@cmanoopckr
Just a suggestion. Based on your lens arrangement, you could create an image of the fiber core at the delivery plane. The spatial light distribution will be the same as that of the fiber output, i.e. probably not uniform, but if you are OK with it, keep reading.
As a first order approximation (and starting point), you have a core with a diameter of 1000um that you want to bring down to 50um. This is a magnification of 50/1000 = 0.05X. The magnification of your two lens system is given by the ratio of the collimator lens focal length over the focusing lens focal length. So, if you choose a 10-mm focal length collimator, and a 200-mm focal length focusing length, this will be a magnification of 10/200 = 0.05X. In this arrangement, the distance between the two lenses doesn’t matter much (the magnification will remain 0.05X, vignetting and telecentricity might be affected).
I hope this helps.
cmanoopckr
  • November 7, 2024
Thanks for your help :)
