DLL (User-Defined Surface): Sequential Vortex Phase Plate
Michael Cheng
This DLL models a Vortex Phase Plate. It is useful in laser applications to convert a Gaussian laser beam into a donut-shaped energy ring.
For more information, check the following links:
https://www.holoor.co.il/wp-content/uploads/2017/11/vortex_zemax_tutorial.pdf
https://www.holoor.co.il/application/optical-vortex-phase-plate-application-notes/
https://www.holoor.co.il/optical-calculator/vortex-lenses/
The Vortex phase plate is a phase surface:
Click here to download
2021/03/20 1.0 - Creation
kot_letova
  • Student
  • 5 replies
  • October 22, 2024
Is it possible to predict theoretically the radus of the first ring (while interacting with plane wave) according to the plate diameter, charge and focal length of the lens? Just to estimate the precision of modelling
kot_letova
  • Student
  • 5 replies
  • October 22, 2024
UPD: I’m afraid, you have a mistake in your program. Your pattern is wrong.
  • 1122 replies
  • October 23, 2024
@kot_letova
It will probably help @Michael Cheng a lot if you can tell him what mistake is in the program if you’ve found one. Perhaps, you could illustrate the issue with an example, that would be even better.
Michael Cheng
  • 143 replies
  • October 25, 2024
Hi @kot_letova,
As David suggested, that would be helpful if you can explain more details what you are expecting and why. I would be happy to have more look. Thank you!
Michael
