DLL (User-Defined Surface): Sequential Vortex Phase Plate
  • May 5, 2023 8:54 AM UTC
  • 9 replies
  • 1778 views
Michael Cheng
This DLL models a Vortex Phase Plate. It is useful in laser applications to convert a Gaussian laser beam into a donut-shaped energy ring.
For more information, check the following links:
https://www.holoor.co.il/wp-content/uploads/2017/11/vortex_zemax_tutorial.pdf
https://www.holoor.co.il/application/optical-vortex-phase-plate-application-notes/
https://www.holoor.co.il/optical-calculator/vortex-lenses/
The Vortex phase plate is a phase surface:
Click here to download
2021/03/20 1.0 - Creation
kot_letova
  • Student
  • Oct 22, 2024 6:12 AM UTC
Is it possible to predict theoretically the radus of the first ring (while interacting with plane wave) according to the plate diameter, charge and focal length of the lens? Just to estimate the precision of modelling
kot_letova
  • Student
  • Oct 22, 2024 5:32 PM UTC
UPD: I’m afraid, you have a mistake in your program. Your pattern is wrong.
@kot_letova
It will probably help @Michael Cheng a lot if you can tell him what mistake is in the program if you’ve found one. Perhaps, you could illustrate the issue with an example, that would be even better.
Michael Cheng
  • Oct 25, 2024 2:06 AM UTC
Hi @kot_letova,
As David suggested, that would be helpful if you can explain more details what you are expecting and why. I would be happy to have more look. Thank you!
Michael
lijia2025
  • Dec 2, 2025 7:40 PM UTC
Hi ​@Michael Cheng,
    I download your vortex phase plate .dll file and used in my optical system model, however, it results in a non-symmetrical, off-axis doughnut beam patterns like follows. Since I used LD source light coupled into a SMF with APC connector (8-degree), I tried to eliminate such connector tilt angle impact on output beam patterns, so I tune the fiber end-put surface to vertical with zero angle, then I noticed the following error screenshots. I am not sure if I set anything incorrectly in the attached .ZAR file, so if you or someone can help take a look, it would be greatly appreciated,
Michael Cheng
  • Dec 3, 2025 1:11 AM UTC
Hi lijia2025,
I downloaded the file and update the system, but I don’t see the error message. I think this is more specific to a system, which needs more investigation. I would suggest sending this to support team so we can help to have more check.
Michael
lijia2025
  • Dec 3, 2025 1:23 AM UTC
Hi Michael,
   In my uploaded model, if you modify y-tangent of fiber APC 8-degree angle to zero, indicating a symmetrical incident beam case, you would find the above error message.
Michael Cheng
  • Dec 3, 2025 1:25 AM UTC
Hi lijia2025,
Could you submit this to support team so we can have more investigation? I’m afraid it’s probably not a good place to check complicated system issue in community. Sorry for the inconvenience.
Michael
lijia2025
  • Dec 3, 2025 1:28 AM UTC
Yes, I have already submitted it to the support team, the case number is 00559640.
