What is mean by weights in wavelength tab?
  • July 27, 2021
  • 704 views
I would like to add sunlight spectrum into wavelength tab in opticstudio. Can anyone help me with how to define weights for each wavelength in sunlight spectrum?
Hi Sathya
The weights represent the importance of the wavelength. They can be linked to the spectral irradiance.
For example below I have copied a sun spectrum. If the weight for the peak is 1, then you can define all the other wavelengths relatively to that value.
I hope it helps.
Hi Sathya
I hope it helps.
  • July 28, 2021
Dear Sandrine Auriol, many thanks for your answer.
