Source TE Polarization
  • April 23, 2021
  • 230 views
Hello together,
how can I model a TE polarized Source Diode?
Short to the background:
I want to hit an object with the light beam and than I change the angle of incident. So normally you should see the Brewster angle, don't you? My problem is, that I can not see the Brewster angle.
Thank you very much for your help.
Best
Christian
Hi Christian
I have attached an example demonstrating the Brewster angle. Let us know if it helps.
Sandrine
