Hi all,
I used the method 1 from this article (Resolution of diffraction-limited imaging systems using the point spread function) in knowledgebase to calculate the resolution of my optical system, and got some weird results. When distance between two points are 10um, I can see they are two objects (see fig1). However, when the distance increase to 15um, the two objects are not distinguishable ( see fig2). Then if the distance continue increase to 30um, the two objects are distinguishable again. Do I miss something here? The results don’t make sense to me. Any comments would be helpful.
Xiaolei
