This is a very open question. Any knowledge insights & advice on how to approach this problem from an imaging systems perspective is greatly appreciated.
How to model for the optimal distance ΔD required position a parallel plate glass in front of a sensor surface such that particles of a given size/dimensions on the window will not form a focused image on the sensor for a given imaging system such as below?
In other words, how to desensitize the window (parallel plate glass) by positioning it between the tube-lens and sensor such that a contamination of size X on the window will not form a focused image on the sensor.
Are there any rules-of-thumb that dictate max tolerable contamination size which shall not affect the image quality. Image quality here meaning it does not form a focused image on the sensor (not MTF degradation).
Cheers!
Best answer by MichaelH
