Non-sequential object with an aperture and a coating
  • 29 March 2024
  • 46 views
I am trying to create a circular beamsplitter with a 50:50 ideal coating on the top semicircle and no coating on the bottom semicircle. How can I achieve this?
So far I have tried to insert a “Standard Surface” at the front face of the glass wedge, applied a custom aperture to the surface, but then I found that I cannot apply a custom coating from MYCOATINGS.DAT to a Standard Surface in NSC.
Next, I tried to create a very thin cylindrical volume in front of my beamsplitter substrate. I applied my 50:50 coating to this surface, but I found that I could not apply an aperture.
So if I use a surface, I cannot apply a coating. If I use a volume, I cannot apply an aperture. What am I missing here?
Thanks!
Userlevel 3
Badge
Try to use two volumes with different coatings on it.
Userlevel 4
Badge +2
Hi Julian,
Maybe you can also try to use a “Standard Lens” object, whose front and back sides can be coated independently? You can see an example in this article: How to model a dichroic beam splitter – Knowledgebase (zemax.com)
and may find this one useful, too: How to add coatings and scattering functions to Non-Sequential objects – Knowledgebase (zemax.com)
