Is it possible to import a STEP file model of an optical system into Zemax?
Hi James,
Yes, objects may be imported in either IGES, SAT, or STEP format, and once imported, an object may have optical properties such as coatings, glass, and scattering functions applied, and then be ray traced like any other optical component.
To import an object, set the object type to “CAD Part: STEP/IGES/SAT” and select the file name from the drop-down box, or place the file name in the comment column. The file must reside in the
This article describe how to import CAD objects into OpticStudio:
