How to generate a resolution target object on a curved surface?
  • 28 September 2023
  • 113 views
Userlevel 5
Badge +3
I would like to perform image simulation by first generating a USAF 1951 3-bar target on a curved object surface concave toward the entrance pupil, rather than on a flat surface object.  Has anyone tried that before?  How to do it?
Thanks, Mike
icon
Best answer by Jeff.Wilde 28 September 2023, 07:26
Userlevel 7
Badge +3
This post may be of some help:
When using a paraxial lens for imaging, the curved object surface produces field-dependent defocus as well as distortion.
Not sure if you want to apply correcting pre-distortion…
Userlevel 5
Badge +3
Thanks Jeff, but how did you apply the USAF target pattern on a curved object?  That’s what I’m asking.
Userlevel 7
Badge +3
I just put a radius of curvature on the object surface.  Now the field points have a z-component given by the sag of the object surface.
