I would like to model Long Pass DM ( >665nm), my laser is 785 nm and a collected signal from the sample below 665 nm. I read the article on dichroic mirror simulation, but in my simulation, I need two light sources. For the excitation light 785 nm I don’t see a problem, however on the sample, at the same point the detector (for the excitation beam) and light source ( for the light from the sample >665 nm) is needed. How to locate to two different components of different functions at the same location? I want to add, that this is my assumption that this could be done that way.
Thank you,
Marzanna
Best answer by Chandan.Maurya
