ZPL: OPEN / READ binary data
  • 10 February 2023
  • 6 replies
  • 217 views
Userlevel 1
Hello community,
I am looking for an example of OPEN / READ / WRITE a binary file in ZPL.
Many Thanks!
Hans-Jürgen
icon
Best answer by David.Nguyen 10 February 2023, 16:12
Userlevel 7
Badge +2
Hi Hans-Jûrgen,
I could be wrong but the Help File for OPEN reads:
Opens an existing text file for reading by the READ command.
This is only for text files, not binary files.
Also, I suggest writting binary files with MATLAB or Python. I wrote an example for Sources here in Python.
I hope this helps. Take care,
Userlevel 1
Hi David,
thanks!
I was in the wrong help section (Tolerancing ) and found OPEN FILE filename mode (mode = [txt,bin]).
That’s pity.
Is it worth to be a support request?
Best Regards
Hans-Jürgen
Userlevel 7
Badge +2
Hi Hans-Jûrgen,
If you want my honest opinion, it isn’t worth it. Reading and writting binary files is a relatively basic task (at least if you know the syntax) in many other more general programming langages including C/C++, C#, MATLAB, Python. Many people, like myself, create our binary files with another langages, which also have a better integrated development environment (IDE). Therefore, I doubt there will be a huge incentive to have it in ZPL in the future. But you can still ask I guess.
Have you had a look at the code I sent you?
Userlevel 1
Hi David,
thanks for the honest answer.
My problem is to replace missing MODIFYSETTING myself by manipulating the cfg files.
I might as well outsource that if I could launch a program (.exe) from ZPL (?).
Grüße
Hans-Jürgen
Userlevel 7
Badge +2
Hi Hans-Jürgen,
Could you use the ZOS-API instead? You’d already be in an environment where writing/reading binary files becomes possible. Running executables as well.
Userlevel 1
Hi David,
thanks. We know that extensions are more powerful.
ZPL is enough for many things. And I like to push the limits.
Ok, for this task / problem we will use ZOS-API.
Viele Grüße
Hans-Jürgen
