The semi-diameter of some radially symetric surface is set to “automatic”. From the Zemax help, I understood that the diameter is adjusted so that no rays are clipped.I´m confused by the mechanical semi-diameter, which in some cases takes a smaller value than the semi-diameter. See picture.
Shouldn´t the mechanical semi-diameter always be larger than the semi-diameter? Why isn´t it so, when all the values are set to automatic?
