Loading User Defined Surface dll with ZOS API python and Matlab
  • 17 February 2022
  • 318 views
Userlevel 4
Badge +1
In opticStudio ,we can set User defined surface through Python and Matlab program using standalone and Interactive Extension.
-Set the user defined surface
-Select the User defined surface from directory
-Get the User defined surface
Matlab Code:
You can directly copy the code in Standalone or Interactive Extension:
   import ZOSAPI.*;
    % Set up primary optical system
    sampleDir = TheApplication.SamplesDir;
    testFile = System.String.Concat('C:\test\ABCD\ABCD Simple_lens.zmx');
    TheSystem.LoadFile(testFile, false);
    TheLDE = TheSystem.LDE;
    surf2 = TheLDE.GetSurfaceAt(2);
    typeSettings = surf2.GetSurfaceTypeSettings(ZOSAPI.Editors.LDE.SurfaceType.UserDefined);
    filesAvailable = typeSettings.GetFileNames();
    typeSettings.Filename = filesAvailable(5);
    surf2.ChangeType(typeSettings);
    d=typeSettings.Filename;
    disp(d)
Interactive Extension Matlab
Python  Code:
# Insert Code Here
testFile =r"C:\Double Gauss 28 degree field.zmx"
TheSystem.LoadFile(testFile,False)
test = str(TheSystem.GetCurrentStatus())
print(test)
surf2 = TheLDE.GetSurfaceAt(1);
print(typeSettings.Filename)
Interactive Extension Python
Download
Be the first to reply!
