Hi all,
I am facing an issue when using the Image Simulation tool via the ZOS-API. The goal is to vary a certain variable in a loop (in this case the object distance), perform each time an image simulation, and save the image with a specific name to a file. However, I notice that the previous images are always overwritten when a new image is saved.
This is the simple MATLAB code that I am using in the main body:
sampleDir = 'D:\Zemax OpticStudio\';
testFile = System.String.Concat(sampleDir, '\Test_ImageTelecentric_Issue.zos');
TheSystem.LoadFile(testFile,false);
TheLDE = TheSystem.LDE;
zline = 0;
surface = TheLDE.GetSurfaceAt(zline);
zvec = =1100,1500]; %variable object distance
for z = zvec
surface.Thickness = z;
index = 3; %existing Image Analysis window with correct settings
im_analysis = TheSystem.Analyses.Get_AnalysisAtIndex(index);
im_settings = im_analysis.GetSettings;
im_settings.OutputFile = ='z',num2str(z),'.png']; %change file name according to variable
im_analysis.ApplyAndWaitForCompletion(); %save image
TheSystem.Save();
end
Although I seem to change the OutputFile before running the analysis, the previous image is always being overwritten:
The ZEMAX archive file is found in attachment.
I would be very glad if someone could point out what the issue could be.
Indy
Hi Indy,
The method TheSystem.Analyses.Get_AnalysisAtIndex(index) actually causes a refresh of the analysis window, the same as clicking the 2 blue circular arrows in the Image Simulation GUI.  So calling surface.Thickness = z; will change the object distance in the LDE, the Get_AnalsysiAtIndex will force an update with the old OutputFile name, then you run the Image Simulation (actually for the 2nd time) and then save the new file.
If you want to keep your current logic, then I suggest after the ApplyAndWaitForCompletion(), you use Matlab to rename/move your PNG file.  Actually, you can simply run the ApplyAndWaitForCompletion() and then move the file to a new folder so you’re not running IS two times.
Hi Michael,
Thanks a lot for the fast and clear reply!
Indeed, changing the code with a file rename as follows solved the problem:
index = 3;
name_folder = 'C:\Users\imagnus\Documents\Zemax\IMAFiles\';
name_old = 'z.png';
name_new = 'z',num2str(z),'.png'];
system("rename " + name_folder,name_old] + " " + name_new);
Indy
