Y stretch in the 3D Layout view
  • Mar 4, 2024 11:15 PM UTC
  • 178 views
axolotl
I have a large aspect ratio design that I have been viewing with the cross section layout tool using the Y Stretch setting. Is there a similar way to scale the X and/or Y axes without modifying the Z axis in the 3D layout tool? Thanks!
Best answer by Kevin Scales
Sorry, but the stretch tool is only available in the Layout tool, because the view there is very simple and easy to scale. You can’t rotate the view in different directions, which would require a much more complicated render. So, it’s only the Layout view.
Kevin Scales
  • Apr 18, 2024 8:29 PM UTC
