Hi everyone,
i am trying to design a refractive beam shaper to generate a collimated top hat beam of emitting beam from a laser diode.
- Approach: To simplify the design, i defined the beam source circular and not elliptical. After parameter-design for fast axis i will scale the lens and use the scaled parameter for slow axis. All as compound element.
- With the flint lens i try to achieve top hat distribution before clown lens and collimate it with the clown lens. Distance between lenses is not variable (about 2mm)
- for my merit function i took Spot Radius(Target 4mm) + Spatial uniformity(Target 0) → NSC
- Variables: radius, conic, coeffr4, coeffr8
The result of optimization due to uniformity is nit satisfying. Is there any additional merit function or any other method to achieve a good uniformity?
