Tolerancing issue occurs when using vignetting factors?
  • 17 June 2024
  • 76 views
I run a tolerancing with my optical system which includes a tolerance script to get RSRE operand in MF.
At first, the warning massage "when using vignetting factors, user-defined fields are required" was popped, then I continue to run the tolerancing with Sensitivity Mode and 5 Monte Carlo Run/Saves.
The Analysis of Tolerances shows that there is no any RSRE and Criterion change in both Min/Max and Monte Carlo runs
I checked the MC_T0005.ZMX, the RSRE and MF have been changed as I expected.
 I’m not sure if the setting vignetting factor is the root cause here. What should I do to make MF operands update correctly in the Analysis of Tolerances?
Thanks
Be the first to reply!
