POP window updates before I finish setting the setting value.
  • March 27, 2024
  • 94 views
Why does the POP analysis run after every single settings change. What if I wish to change other settings also.  The POP algorithm goes off on a long analysis run  that can be terminated  (there is also a waiting period for terminate to complete) Is there a way to make multiple changes to settings without the analysis starting before I finish?
Problem solved. Unclick the Auto Apply button.
Best answer by Kevin Scales
Correct. The Auto Apply button is the method to avoid this sort of thing for many tools. All’s well that ends well.
Kevin Scales
