Hi there,
I try to model a hyperhemispherical object in the non-sequential mode, however, Zemax won’t let me to do so. I get an error saying “cannot create object because there are too many faces in the source objects”. I tried to use the Boolean operation and substracted a zylinder object from a sphere. This works for truncated spheres until a hemisphere results. If I shift the zylinder further and the result would be a hyperhemispheric object the error occurs.
Is there another possiblity to create a hyperhemispherical object?
Many thanks for your help! :)
