Is there a way to specify the following in the ISO element drawing tool:
- Vd in %
- Radius in %
Thanks
Best answer by Jeff.Wilde
View originalIs there a way to specify the following in the ISO element drawing tool:
Thanks
View originalIf you use the Tolerance Data Editor Wizard, then you can supply percent tolerance values for radius and Vd.
The percentages are converted into corresponding tolerance values that can subsequently be displayed on the ISO Element print. I don’t think there is a way to have OpticStudio create tolerance values on the prints that are the % values themselves.
