Is there a way to increase the maximum number of pixels allowed in non-sequential detector?
  • Mar 31, 2021 5:01 AM UTC
  • 322 views
I'm trying to simulate a large size but high resolution detector in non-sequential mode. So I need both large number of rays and small pixel detector. But OS is capping my maximum number of pixels at 6000 and maximum number of rays to 1e9. Is there a way to increase those? computation, speed and time are not an issue. It can take as much time needed or the memory. Lemme know if I can change those settings some where to push to higher resolution. Thanks
Berta.Bernad
  • Mar 31, 2021 8:30 AM UTC
Hi Ginni,
As you said, the maximum number of pixels is 6000 and there is no way to change that limitation. As a workaround, you can try to use a set of detectors to cover the full detector area (using several detectors instead of just one).
For the number of rays, each source has a limit of 4E+9 rays. If you need to trace more analysis rays, maybe you can overlap several source objects.
Berta
