How to set the Y start order and Y stop order of grating object via API?
  • October 24, 2024
  • 69 views
Shenwu Yang
I got an issue when I set the parameters of grating object via API.
When I set other parameters of grating object via API, the preset Y start/stop order will change to 0 automatically.
And I am trying to find a function to set the Y start/stop order in API, it turns out there is only property named start order can be set.
So this issue is the Y start/stop orde will be changed to  0 automatically when I am setting other parameters, and I cannot set the Y order via API.
  • October 24, 2024
@Shenwu Yang
As far as I tested, those parameters are indeed missing and I also observe the same behavior that Y Start/Stop goes to zero 😔
