How to set the desired surface efficiently
yuan.chen
There are two different approaches to do this. Take Radial Grating as example.
  1. Click the tab at the right position of standard surface.
    And then  pressed R instead of clicking the standard surface column directly.
  2. Select the surface and click directly and then enter the name you want to search. In our case, it starts with r. This method provides a way to search the surface with certain letter inside the surface name.
Be the first to reply!
