I’d like to make a reflective diffuser surface (basically engineered diffuser). Behavior would be:
The diffusiveness is defined by grain size (p),
and the incoming ray would be randomly diffused according to diffraction equation:
sin(theta_out) = sin(theta_in) ± lambda/p * randomness
randomness varies between [0-1]
I couldn’t find it in the scattering option. How could I model this?
If given instruction, I think I could use user defined surface.. but I’m not sure if there is easier way.
Thank you for your attention!
