I know a mirror surface without coating is treated as 10um-thick Al coated. If I apply mirror to a surface in the meanwhile also apply taper coating, how does ZEMAX handle the coating stack. In this case, what would be the substrate? Will POP work for this coating stack? Thank you very much.
Best answer by mojtaba.falahati
