I’m trying to write a script using the Zemax API to run the ghost focus generator, save the files, and then do analysis on the resultant files.
I don’t see anything in the documentation for the API about running the ghost focus generator and searches of the API documentation turn up no results. Is it possible to run the ghost focus generator from the API? If so, where can I find the syntax?
Thanks!
Best answer by MichaelH
