Hello. I’m new to a lot of features of OpticStudio, including tolerancing, and I have a question that likely stems from my lack of understanding of what the program is doing. In the Tolerancing user interface → Criterion tab, when in Inverse Limit mode, there is a button labeled “Check” that becomes available. I was under the impression that this checks the nominal value of the specified criterion. In this screenshot I have it set up to evaluate the geometric MTF at a spatial frequency of 8 cycles per mm (I assume those are the units?), and after clicking the “Check” button I get a value of 0.087. There is no compensation in the system.
Shouldn’t this value then be the same as (or at least close to) what the geometric MTF in the Analyze tab would provide? In the screenshot below it’s clear that the average for all fields at 8 cycles per mm is well above 0.087.
Am I misunderstanding what the “Check” button is doing? Thanks for your time!
Best answer by mojtaba.falahati
