Extracting Complex Components of POP
  • 7 June 2023
  • 66 views
I have a quick question regarding using the POP in sequential mode. Is there a way to extract the real and imaginary components of each part of the complex number array of the POP matrix that is used to compute the phase and intensity of the POP beam? Preferably as a CSV file? Thanks!
icon
Best answer by MichaelH 8 June 2023, 01:40
Userlevel 6
Badge +2
Hi Armand,
There is not a built-in way to get the electric field.  However, the real & imaginary components of the x & y e-field are saved in the ZBF file.  You can either use the ZPL with the ZBFREAD keyword or you can use the ZOS-API.  The Help Files have a really good example for using ZBFREAD...I have modified it slightly to output a more readable format:
! modified from the Help Files
BROWSE "Select ZBF file", zbf$, 0
IF SLEN(zbf$) == 0 THEN END
! First get the beam size
ZBFPROPERTIES zbf$, 1
nx = vec1(1)
ny = vec1(2)
ip = vec1(14) # The "is polarized" flag
! Allocate enough memory to hold the beam
IF (ip == 1)
PRINT "this example only handles unpolarized beams"
END
ENDIF
DECLARE B, DOUBLE, 3, nx, ny, 2
DECLARE P, DOUBLE, 1, 20
ZBFREAD zbf$, B, P
real$ = $TEMPFILENAME()
imag$ = $TEMPFILENAME()
FORMAT 12.6
! print data to text files
OUTPUT real$
PRINT "Real Data - ", zbf$
FOR j, 1, ny, 1
FOR i, 1, nx, 1
PRINT B(i, j, 1),
NEXT
PRINT
NEXT
OUTPUT SCREEN
OUTPUT imag$
PRINT "Imaginary Data - " , zbf$
FOR j, 1, ny, 1
FOR i, 1, nx, 1
PRINT B(i, j, 2),
NEXT
PRINT
NEXT
OUTPUT SCREEN
! show the data
SHOWFILE real$
SHOWFILE imag$
Michael C also wrote some really good parsers if you want to use the ZOS-API.
Python Reading Writing Binary Files (ZRD, ZBF, DAT, SDF) | Zemax Community
