Comparing ZOS files
  • April 11, 2022
  • 286 views
Is there an efficient way to check for differences between two ZOS files?
Yes, it’s possible to save two files as ascii files (.zmx) and compare the two using a text editor with a compare function, but the file is relatively difficult to understand.
It would be nice if there’s a function that highlights cells in the componen editor that’s different from a similar file.
Best answer by Ray
There  is a function to compare files in the File tab, the File Comparator:
It’s not as extensive as comparing 2 zmx files in a text editor, though.
  • April 11, 2022
I missed it.
This is exactly what I was looking for.
Thanks !!
