Chromatic focal shift tool question
  • 12 April 2022
  • 318 views
Hi I have a question about the chromatic focal shift tool in Zemax
when using the tool with thorlabs plano convex lens LA1417 lens the ray diagram and focal shift tool match, where the focal displacement is -2.7mm between 800nm and 1500nm
but when using the tool with thorlabs achromat AC508-150-C  the ray diagram and focal shift tool do not match where the ray diagram illustrates a shift of around +1.3mm and the focal shift tool illustrates a shift +450um?
Clearly the achromat is a thicker lens , is the cause of the difference between ray diagram and focal shift tool ? which method in this instance would be more accurate?
icon
Best answer by MichaelH 12 April 2022, 18:32
Userlevel 6
Badge +2
The reason you’re seeing such a big difference with the doublet between what you see in the Chromatic Focal Length analysis and the Layout is because the CFL uses paraxial rays and the layout as shown is real marginal rays.  For the Singlet, although there is also a difference between the paraxial and marginal focus, the difference is pretty consistent over the wavelength range so it appears that the CFL and Layout are in agreement (even though they are tracing different rays).  The differences becomes much more pronounced when using the difference dispersions of the Doublet to correct for color shift.
So the question of "which one is correct" really depends on what you’re trying to do, but in general, if you have a quantitative analysis like the CFL vs a qualitative analysis like visually looking at the Layout, I would recommend using the quantitative analysis as long as you understand the assumptions.
~Michael
Thanks micheal . I got it. the plano convex is actually a really flat lens where there is not much spherical abberation thus the overlap between paraxial to marginal rays is minimal whereas with the achromat there is significantly more spherical abberation thus there is a mismatch between marginal and paraxial rays. I confirmed this via reducing the entrance pupil diameter of the achromat where the rays traced are only paraxial and thus match the CFL tool
