Biconic Zernike surface producing incorrect results.
  • January 29, 2024
  • 373 views
I have an asphere lens setup in NSC, and want to see the effect of adding an astigmatism to the lens. The only way I see is to use the biconic Zernike surface with all Zernike coefficients set to 0. When enter the lens prescription into the aspheric surface or Zernike surface, I get the correct results. As soon as I switch to the biconic Zernike the results look incorrect. Any ideas on why they do not match?
Spot at 100mm
Best answer by mojtaba.falahati
Hi Chris,
I already emailed you the response, but I post it here as well in case other users come up with the same question.
The Biconic Zernike Surface is described by the following sag equation:
which is not necessarily the same as the Aspheric surface sag given the higher order aspheric terms (X^4 and Y^4 in your model):
This can be seen by superposition of the two surfaces in the 3D Layout:
That's why the illumination patterns are different with Biconic Zernike and Aspheric Surfaces.
Moj
mojtaba.falahati
Hi Chris,
Moj
