I just downloaded OpticStudio for the first time. Is there a beginner's guide that I can work through?
Best answer by Don Dickinson
View originalI just downloaded OpticStudio for the first time. Is there a beginner's guide that I can work through?
View originalThe best place for new users of OpticStudio to start is the “Getting Started Using OpticStudio” section (located under the Help Tab) which contains various Tutorials:
From this Help Tab, you can also find the help documentation (“Help System” or “Help PDF”, depending on preference) as well as links to the Knowledgebase, and the email for technical support.
Hi Allie, When I select that ribbon, I do not see the “Getting started ..” icon? Is there a way to add to the ribbon?
Hello!
Newer versions of OpticStudio removed the Getting Started guide as it was moved online. Instead, click on Knowledge base and it will take you to the main support site.
Once on the support page, there is a Getting Started and Tutorials link in the knowledge base. These contain similar guides to what was included within OpticStudio before.
Hi Don,
Thank you very much.
Stewart
