Advice for solidworks ray trace plugin?
  • 21 June 2024
  • 74 views
Given the break with direct cad exchange with Solidworks and Ansys OpticStudio, can anyone recommend a Ray Trace plugin solution for Solidworks? I’ll still use OpticStudio for all the rigorous analysis and just want a tool that will allow faster iteration with cad geometry directly in Solidworks.
These all seem to be options:
  • RayVis from Lambda Research
  • APEX from Breault Research Organization
  • Photopia from LTI Optics, LLC
Anyone have good/bad experiences with them? Others to consider?
I have no idea on the pricing yet.
Thanks in advance for any advice.
I don’t have any experience to share about these options, but since this is a question about alternatives to Zemax you might want to try asking on the Optics subreddit.
Thanks for the suggestion @Sean Turner,
Here is a link to the post on reddit:
https://www.reddit.com/r/Optics/comments/1dnhhts/advice_for_solidworks_ray_trace_plugin/
I would just work with STEP files unless you need the ability to change the SolidWorks part from within the optical design code. I don’t know if any of the codes mentioned allow that feature or not. But if you’re just raytracing the part and not optimizing it in a closed-loop I’d just use STEP
