ZPL Detector Viewer Update
  • June 5, 2025
  • 6 replies
  • 252 views
I would like to use zpl to update my detector viewer and save it as an image.
However, neither Ray Database nor Filter are adjusted in the detector viewer.
#trace rays & evaluate Detector
filter$ = "h3&h6&!x_hitface(8,0)&!x_hitface(8,2)&!x_hitface(4,0)&(x_hitface(7,1)|x_hitface(7,0))"
filter2$="h3&h6&!x_hitface(8,0)&!x_hitface(8,2)&!x_hitface(4,0)"
fileName$ = "ZMPRays.ZRD"
NSTR 1, 0,0,0,0,1,0,1,fileName$
temp = NSDD(1,0,0,0)
ZRDPlayback fileName$,1,0,1, filter2$
UPDATE ALL
PRINT NSDD(1,9,0,0)
ZRDPlayback fileName$,1,0,1, filter$
UPDATE ALL
PRINT NSDD(1,9,0,0)
settingsFile$= "...\Zemax\Configs\DVR.CFG"
MODIFYSETTINGS settingsFile$, DVW_ZRD, fileName$
MODIFYSETTINGS settingsFile$, DVW_FILTER, filter$
UPDATE ALL
The  PRINT NSDD(….) commands give the correct outputs, but the detector viewer is not updated.
How can I use ZPL to update the detector viewer using the Ray Database fileName$ and the filter string filter$?
  • June 12, 2025
@simon.schroeder_01
Did you see this?
@simon.schroeder_01
Did you see this?
Yes, that’s why I went through the text variables filter$ and filter2$.
I get the right results witht NSDD command, but for the detector viewer, the filter string is not applied.
  • June 16, 2025
@simon.schroeder_01
It might be interesting to see if you can get it to work with 2024 R1.0 to see if its related.
  • June 18, 2025
In 25R1, if I run a very simple simulation with a source, rectangle, and detector where the rectangle blocks half the source, I get the expected results with ZRDPLAYBACK.
Using the following ZPL script, I get the left image when I don’t use a filter string and on the right image when I use an H2 filter.
! user defined filters
filter1$ = "H2"
filter2$ = ""
! run raytrace
fileName$ = "test.ZRD"
NSTR 1, 0, 0, 0, 0, 1, 0, 1, fileName$
ZRDPLAYBACK fileName$, 1, 0, 1, filter2$
! update Detector Viewer window
UPDATE ALL
So I believe the filter strings are working in 25R1 (also 24R2).
Which OpticStudio version are you using?  Can you upload a paired down ZAR file along with your ZPL macro?
Thank you for the example file.
I was using 23R2 and your example did not work.
I have updated to 24R2 and it still is not working for me:
I do get the same images as you only if the detector Viewer has <No Ray Database Selected> selected.
It has the overlay message “Ray trace has not been run”
If it has the “test.ZRD” ray-database, I do not see the filter.
Is the problem “only” to get rid of the  banner?
My solution for now is that I have two detector viewer windows open in parallel.
Both have selected the ray-database and one already contains the filter and the other one has no filter defined.
I then just save the window that I want (either detector with filter or detector without filter).
