Aspheric lens optimization
  • May 20, 2024
  • 11 replies
  • 586 views
Hello Experts,
I am new to zemax design. I want to design a molded aspheric lens by using PMMA material..
Lens diameter is 26mm, EFL is 11.111mm, bfl is 7mm. I can design with single field and single wavelength. But while i am trying to do in multi wavelength and multi field  i am not able to control the edge thickness and aberrations. So please give a suggestion to design this lens. and what are the operands need to use? How to optimize?
Thank you in advance.
Arunpandi
Yang.Yongtao
  • May 21, 2024
Hi Arunpandi
or check zemax manual, the operand table and find what you want to control
  • May 21, 2024
Can you please show yours desgin for 1 field? it will help.
Nadav
  • May 21, 2024
Dear yang,
Thank you for spending your valuable time to reply.
I have boundary values and LONA, operand to control thickness and aberrations. But the shape of the surface and lens become uneven(It form like 3 or E). so how to resolve this?
  • May 21, 2024
Dear Nadav,
Thank you for your kind reply,
Please find attached my design file.
  • May 21, 2024
Dear Arunpandi,
Is the mtf good enought for one field?
what is the maximum field?
  • May 22, 2024
Dear Nadav,
Thank you. max field is 70 degree.
  • May 22, 2024
It is look like your requirements are unfeasible.
70 degree is very big field. Usually several lens are required for such field with larger BFL/EFFL.
  • May 22, 2024
Thank you nadav, for your valuable time and reply.
Yang.Yongtao
  • May 23, 2024
Dear yang,
I remembered there are some operands or methods can control the thickness at designated diameter ,say 0.8 of Full Diameter, this may control the shape of the surface.
I am also searching that….
Yang.Yongtao
  • May 23, 2024
Dear yang,
these ones? I guess
  • June 1, 2024
Thank you yang. I will try
