Wavefront map units
  • May 26, 2025
  • 28 views
Julien Dejonghe
Hi, using the waveront map analysis, the results are always given in waves. Is there a way to display the results in nanometers? Could be convenient when the specifications are in nanometers, and when you have a lot of different wavelengths and fields, the manual conversion is long…
Thanks
Be the first to reply!
