Hi all,
I hope you are well!
I have been doing some axial intensity modelling of various Thorlabs axicons via the Physical Optics Propagation feature. In particular, I am interested in using the AX2520-B axicon. I have imported this using the Lens Catalog, but I am now interested in trying to model the effect of the rounded tip which is a common manufacturing error (as opposed to the perfectly sharp tip which is assumed in the “ideal” case). This radius of tip curvature is typically within the range of 10s of microns, but I am unsure how to go about implementing this within the Lens Data window for carrying out further Physical Optics Propagation analysis?
Thank you for your time and consideration.
Best answer by Mark.Nicholson
