Is it possible to convert a RS8 file to a RSMX file?
rs8 files can be converted to RSMX files.
If needed, send us the link and we will convert it for you.
Thank You, Sandrine. Cree has the following rs8 descriptions that I would like to have converted :
https://www.cree.com/led-components/media/documents/JK3030-3V-559.zip
https://www.cree.com/led-components/media/documents/JK3030-6V-555.zip
Their IES files is only a point source and does not describe the ray generation close to the LED surface
I would indeed appreciate Your conversion and where to find it afterwards. Maybe You could share the
conversion software
Best regards / Börje Emilsson
Hi Borje
Here are the rsmx files:
https://zemax.files.com/f/95f7b9b666e42b0c
https://zemax.files.com/f/9fd049e6c92a544a
The software we use to convert is called ProSource, but we have a license for this so we can't share it.
Sandrine
Please convert the rs8 file of cle into an RSMX file.
https://www.cree-led.com/document-library/?_document_search=CMT%202890
Best regards
RYU
Hi
I’ve converted the file for you, and you should receive an email shortly giving you access to it.
Ethan
Hi
Thank you for conversion.
Can the same data be converted into dat data?
Best regards
RYU
Hi
Would conversion to SDF work as an alternative? If that is the case, you can use the OpticStudio tool Generate Radiant Source Model Rays with the RSMX file that I sent to you. Below is a screenshot of the tool, and you can find much more detailed information to set it up in the Help File: The Help Tab > Zemax Lab Group > Deprecated Features > Radiant Source Models > Generate Radiant Source Model Rays
Ethan
Hi
Unfortunately, my zemax license is professional.
Conversion to SDF data is not possible.
Best regards
RYU
