When using Reverse Elements, Row Colors other than default are not swapped correctly between rows. The user defined color is kept fixed at its original row number, even after reversal.
View originalWhen using Reverse Elements, Row Colors other than default are not swapped correctly between rows. The user defined color is kept fixed at its original row number, even after reversal.
View originalHi Alberto
Sorry for not replying earlier but yes this is a bug. I will report it.
Since it is a cosmetic bug, I won’t set a high priority.
