I lock analysis windows eventually requiring high computation time (for example Geometric Bitmap Image Simulation), so that I can work and update the other windows in the meantime.
When a project file is opened, all the windows update, even if they are locked. This is uncomfortable. I know that I can “Terminate” the computation of analysis windows, but I think that locked windows should remain locked (= not updated) even at the opening of the file.
Thank you
Iari
Best answer by Kevin Scales
